Run plsql from .bat
  • Oct 12, 2017 12:25 PM UTC
  • 13 replies
  • 170 views
I have opended a text file and have an array to pass to SQLExecutor or SQLcreator.
They only appear to work on tables not an input string. Keep getting error reading table - It is a list not a table!!
I need to loop through the array and run a procedure against each value.
I tried to open PLSQL+ using a .bat file, this throws an error
SystemCaller_2: Executing `cd c:\\windows\\system32 && run "cmd.exe"'
The syntax of the command is incorrect.
SystemCaller_2: Failed to Execute `cd c:\\windows\\system32 && run "cmd.exe"'
I aimed to open SQLPlus to read the array in order to run a procedure.
The problems:
  • I cannot get SQLExecutor or SQLcreator to read a string/list (???).
Is it possible to pass the array to loop through and run the procedure??
Any help appreciated.
regards,
Clive
  • Oct 12, 2017 12:33 PM UTC
Can you please be a bit more specific and give us some code examples that shows us what you're working with?
Attached below
The error occurs when I connect SQLExecutor as it is looking for a Table not an array/list.
SQLExecutor_<Rejected>(TeeFactory): SQLExecutor_<Rejected>: Termination Message: 'SQLExecutor output a <Rejected> feature.'
SELECT "NTF" FROM @Value(text_line_data)
The aim is to loop through the list (shown in test-array-2), passing each element to a procedure.
  • Oct 12, 2017 1:02 PM UTC
The first thing that strikes me is that you'll need some double quotes around the table name, e.g.
SELECT "NTF" FROM "@Value(text_line_data)"
But do you really have a table called "0261-D"?
I moved the @Value(text_line_data) ie 0261-D
SELECT @Value(text_line_data)
FROM "NTF"
Feature Type: `FEATURE_TYPE'
Attribute(encoded: utf-8) : `NTF' has value `0261-D'
Attribute(string) : `_reader_error' has value `An error occurred while accessing a table
Still getting an error because "NTF" is an array NOT a table.
How do I get the array into a loop that I can pass to PLSQL+??
  • Oct 12, 2017 1:15 PM UTC
You still need some double quotes around the column name:
SELECT "@Value(text_line_data)"
FROM "NTF"
But does the table "NTF" contain a column called "0261-D"? To me that looks more like a value, in which case you'll probably want something like
select *
from "NTF"
where my_column_name = "@Value(text_line_data)"
You'll of course have to substitue my_column_name for whatever your lookup column is called.
You are correct about the Syntax. Still get the same error!!
The problem is that SQLExecutor needs to read a table. An array is not a Table in Oracle.
The question is still HOW to get an array into a Loop to run a procedure??
  • Oct 12, 2017 1:29 PM UTC
I'm sorry, but I'm struggling to understand. What do you mean by an array in this context? And which procedure are you talking about?
You'll have to tell us a bit more about what you're trying to accomplish.
gio
Forum|alt.badge.img+15
  • Oct 12, 2017 2:09 PM UTC
@clives_online
I use this technique. Looping trough lines in a txt/csv and setting an environment value.
Maybe it's helpful for you.
In your bat file:
FOR /F "usebackq delims=" %%i IN ("%YourTextArray%") DO (
SET YourrelevantValue=%%i
fme.exe %Scripts%\\..\\yourscript.fmw
do some stuff if needed
In yourscript.fmw you then can use a EnvironmentVariableFetcher to get the value "YourrelevantValue" needed to kick of your procedures.
  • Oct 12, 2017 3:33 PM UTC
Thanks for the illustration. If I understand correctly, your anonymous PL/SQL block (on the right side of your illustration) iterates over the NTF table and returns all the values of the NTF column (see "SELECT NTF FROM NTF;" in the PL/SQL)
Would using a SQLCreator with the following SQL give you something similar as what you've got on the left side of your illustration? (Notice that there's no ; at the end of the SQL statement)
SELECT NTF FROM NTF
In the SQLCreator, expose the attribute "NTF", it would look like this:
This should return one feature for each record in the "NTF" table, and each feature will contain an attribute "NTF" with a value such as "0261-D", etc.
Of course, I have no access to your database so I can't test it, but that's what would happen according to my understanding of the situation.
Is this closer to what you had in mind?
SQLCreateator fails because I am trying to read an array outside of ORACLE.
The frustration is trying to get Oracle to read an ARRAY and loop through the Array NOT a Table.
If I was reading a Table, Oracle would be happy and return an Array!!
  • Oct 12, 2017 3:56 PM UTC
Would it be possible to share the DDL of the array, I suppose it's "NTF", here?
  • Oct 12, 2017 4:30 PM UTC
I suspect you'll have to find a way to either CAST the array as a table and SELECT from it, or maybe to call an Oracle function that returns the array values as a concatenated string which you can then split into individual features in FME (e.g. using the AttributeSplitter).
