Run FEATUREREADER only if records pass testers but don't pass records to FEATUREREADER.
  • Apr 7, 2021 3:00 PM UTC
  • 95 views
dkirouac
Forum|alt.badge.img+5
I want to trigger a FEATUREREADER to run only if there are records that pass a tester. But I don't want to pass all the records to the FEATUREREADER, only trigger the reader to start. The passed tester records will be used in a different transformer but I also want to trigger the reader to start if there are any records that pass the tester. What is the best way to accomplish this?
Thanks,
David
  • Apr 7, 2021 3:11 PM UTC
Hi @dkirouac​ , you can use the Sampler to pick the first (or the last) one feature in the passed features then kick the FeatureReader.
  • Sampling Rate: 1
  • Sampling Type: First N Features
dkirouac
  • Apr 7, 2021 5:03 PM UTC
  • Sampling Rate: 1
Thank you takashi. I will give it try.
