Run button grey's out Post successful execution (running with Cache turned on).
  • Feb 16, 2023 11:33 AM UTC
  • 27 views
Run button grey's out Post successful execution . I'm running with Cache turned on. But SQL operation is not executed
egge
Forum|alt.badge.img+14
  • Feb 16, 2023 2:53 PM UTC
Yes, you are right: the Run button is greyed out after successful execution of a workspace. (If you want it to run again anyway, you will have to use the option Rerun Entire Workspace (or Shift+F5)).
From the screen dumps you have provided I would say that the SQL operation has been executed but did not return any results. Could that be true?
To investigate the issue you could have a look at the Translation Log. And what happens if you execute the query directly on the data source? Does it return any records there?
