Rotation of 3D Object when writing to KML
  • Sep 10, 2021 6:24 AM UTC
  • 106 views
Hello again, apologies for the questions, i am fairly new to FME and this one is baffling me. To me, this is a fundamental question, but through much research, I haven't found a solution as yet.
I try to research before I post in forums.
IS there any way to write a bearing of my 3D Object on writing out to KML ?
rotationMaybe I should rephrase this as I CAN actually rotate the object.
What I would like to do as an option, is somehow have this parameter/attribute in the KML file so that when you click on the properties of the KML, you can input the Angle/HEading/Bearing at this point.
The ultimate goal would be to get all bearings from a CSV / External Data source, along with the model type to be used, and on writing to KML would have the correct model at the correct bearing. This is a big one actually and fundamental to a particular use case I'm looking at.
RadiationZone
danminneyatsaf
Forum|alt.badge.img+13
Hi @chuttonx​, I just wanted to ask a few things before moving forward with any suggestions.
  • Are you trying to use the bearings from a CSV/External Data source to set the rotation of a specific 3D Object in the KML file?
  • If it is for a specific 3D Object, does the 3D Object have an ID or name that could be used for matching bearing values with the correct object?
  • Additionally, if you're comfortable, would you be able to share you workspace & a sample dataset here?
caracadrian
Forum|alt.badge.img+23
  • Sep 14, 2021 4:40 AM UTC
If you want to use the bearing in your workspace it's as simple as using it as an attribute in Rotator->Rotation Angle (through arithmetic editor).
