REST API call from FME HTTPCaller gives an error of "HTTP/2 400" but from Postman it works fine
  • Apr 25, 2024 9:56 PM UTC
  • 11 replies
  • 804 views
missp29
Hi All,
I have FME Form 2023.2.
I am trying to make a REST API call using HTTPCaller. I got this error below,
    "code": "data_validation_error",
    "message": "Invalid request values. Unexpected character ('_' (code 95)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')",
    "status": 400,
    "traceId": "240425163408767-2c15ec9a"
However, the same request works just fine on Postman. Not sure what exactly the error means here. Can anyone help me on this?
Here is the HTTPCaller screenshot.
Here is the request body,
Here is the error messages from the Translation log.
UpdateRecordCustomTablesHTTPCaller (HTTPFactory): An error occurred while accessing the URL 'https://apis.accela.com/v4/records/PINELLAS-24CAP-00000-0004H/customTables'
The below feature caused the translation to be terminated
Storing feature(s) to FME feature store file `C:\FME\Funeral Home\FuneralHomeBillingInterfacefmw_log.ffs'
Feature Type: `FEATURE_TYPE'
Attribute(string: UTF-8)          : `ApprovalDate' has value `2021-12-29'
Attribute(32 bit unsigned integer): `CACNumber' has value `2118566'
Attribute(string: windows-1252)   : `DeceasedFirstName' has value `xxx'
Attribute(string: windows-1252)   : `DeceasedLastName' has value `xxx'
Attribute(string: windows-1252)   : `DeceasedMiddleInitial' has value `xxx'
Attribute(string: windows-1252)   : `FHIdentifier' has value `F040344'
Attribute(string: UTF-8)          : `RecordId' has value `PINELLAS-24CAP-00000-0004H'
Attribute(string: UTF-8)          : `_RecordCustomTablesJson' has value `[ { "id" : "HS_CREMATION-GENERAL.cINFORMATION", "rows" : [ { "action" : "add", "fields" : { "Cremation Approval Number" : "2118566", "Cremation Date" : "2021-12-29", "First Name" : "xxx", "Middle Name" : "xxx", "Last Name" : "xxx" }, "id" : 1 } ] } ]'
Attribute(string: UTF-8)          : `_error' has value `HTTP/2 400'
Attribute(16 bit unsigned integer): `_http_status_code' has value `400'
Attribute(string: UTF-8)          : `_response_body' has value `{"status":400,"code":"data_validation_error","message":"Invalid request values. Unexpected character ('_' (code 95)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')","traceId":"240425215017149-42dfe79c"}'
Attribute(string; UTF-8)          : `fme_feature_type' has value `CSV'
Attribute(string: US-ASCII)       : `fme_geometry' has value `fme_undefined'
Attribute(string; UTF-8)          : `fme_rejection_code' has value `NO_RESULT'
Attribute(string: US-ASCII)       : `fme_type' has value `fme_no_geom'
Coordinate System: `'
Geometry Type: IFMENull
Coordinate Dimension: 2
UpdateRecordCustomTablesHTTPCaller_<Rejected> (TeeFactory): UpdateRecordCustomTablesHTTPCaller_<Rejected>: Termination Message: 'UpdateRecordCustomTablesHTTPCaller output a <Rejected> feature.  To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
Translation FAILED with 3 error(s) and 0 warning(s) (0 feature(s) output)
Here is the screenshot on Postman.
Thanks,
-John
nielsgerrits
Forum|alt.badge.img+67
Do you have the same headers in Postman? What happens if you remove Accept from the headers?
missp29
  • Apr 26, 2024 2:50 PM UTC
Thanks, nielsgerrits
With your hint, I have some new findings.
I played the Headers on Postman. Here are the least settings I can have to make a successful call on Postman. All I need are three attributes, Authentication, Content-Length and Host.
If I removed the attribute Content-Length, I got this error,
    "status": 400,
    "code": "bad_request",
    "message": "Request body is required.",
    "traceId": "240426143249919-6eda4c52"
If I removed the attribute Host, I got this error,
<!DOCTYPE html
    PUBLIC '-//W3C//DTD XHTML 1.0 Transitional//EN' 'http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd'>
<html xmlns='http://www.w3.org/1999/xhtml'>
<head>
    <meta content='text/html; charset=utf-8' http-equiv='content-type' />
    <style type='text/css'>
        body {
            font-family: Arial;
            margin-left: 40px;
        img {
            border: 0 none;
        #content {
            margin-left: auto;
            margin-right: auto
        #message h2 {
            font-size: 20px;
            font-weight: normal;
            color: #000000;
            margin: 34px 0px 0px 0px
        #message p {
            font-size: 13px;
            color: #000000;
            margin: 7px 0px 0px0px
        #errorref {
            font-size: 11px;
            color: #737373;
            margin-top: 41px
    </style>
    <title>Service unavailable</title>
</head>
<body>
    <div id='content'>
        <div id='message'>
            <h2>Our services aren't available right now</h2>
            <p>We're working to restore all services as soon as possible. Please check back soon.</p>
        </div>
        <div id='errorref'>
            <span>            </span>
        </div>
    </div>
</body>
</html>
So on FME, just follow what I have on Postman, I only set three same Headers attributes, Authentication, Content-length and Host. I found what the values of Content-length and Host are from Postman Console.
Content-Length = 550
Host = “apis.accela.com”
When I run it, it gave me a different error of HTTP/2 421 this time. The response body is the same as one of two scenarios above where I removed the attribute Host from the Headers on Postman. It seems to me the Attribute Host on FME doesn’t make any difference as it does on Postman. is there a way we can look into the whole request Headers, the Headers which is sent out,  on FME?
Thanks,
-John
missp29
  • Apr 26, 2024 3:19 PM UTC
I posted a reply a few minutes early this morning. Somehow it didn’t show up. Let me try again.
First, to your question. If I removed the Headers attribute, I got the same error.
With your hint, I played a little bit more on Postman and have some new foundlings. Here is the least Headers settings I have to make a successful call on Postman. All I need are three attributes, Authentication, Content-length and Host.
When I removed the attribute Content-type, I got this error,
    "status": 400,
    "traceId": "240426150945036-c8dc66b8"
When I removed the attribute Host, I got this HTML response back.
<!DOCTYPE html
<head>
        body {
            font-family: Arial;
            margin-left: 40px;
        img {
            border: 0 none;
        #content {
            margin-left: auto;
            margin-right: auto
        #message h2 {
            font-size: 20px;
            color: #000000;
        #message p {
            font-size: 13px;
            color: #000000;
        #errorref {
            font-size: 11px;
            color: #737373;
            margin-top: 41px
    </style>
</head>
<body>
    <div id='content'>
        <div id='message'>
        </div>
        <div id='errorref'>
            <span>            </span>
        </div>
    </div>
</body>
</html>
Now I follow the same on FME. I only set up three Headers attributes Authentication, Content-Length and Host. I found what the values of Content-Length and Host are from the Postman Console.
Content-Length = 490
Host = apis.accela.com
When I run it on FME, I got the same error as the scenario above where I removed the Headers attribute Host on Postman. it seems that the Headers attribute Host doesn’t have any effect on FME as it does on Postman. Is there a way I can look into exactly what the Headers attribute on Post man when it sends the request out?
Thanks,
-John
tva
Forum|alt.badge.img+13
  • Apr 27, 2024 11:28 AM UTC
There is a way to show in postman what the exact call with headers etc is. Right arround the button where you make the call there should be something like this </> that shows the code. I didn't find something similar in FME.
I do read that your postman call return 200 but the message also indicates it is an error?
Did you verify that the number and id in your request body should be strings?
Sometimes I put Content-Type directly in the header as well
tva
  • May 3, 2024 2:26 PM UTC
@missp29  it’s indeed the </> sign in postman that gives you how the call exactly looks like.
This is the example from the data you provided in FME
I see this from what you mention in postman:
The difference is at the end:
in your FME call it’s “id”: 1  → this 1 is an integer
in your postman call it’s “id”: “1” → this 1 is a string
So your issue might also be related with this
missp29
  • May 3, 2024 3:43 PM UTC
@tva Thank you very much for your help.
If you see my original screenshots on FME, in one of template data, I did use “id”: “1”. I don’t data available right now. I will test again with both Integer and String once I have data available. I will let you know soon.
Thanks,
-John
tva
  • May 3, 2024 5:00 PM UTC
Hi @missp29 ,
Once you have data again, lets go back to the initial structure that worked in postman and show us also the code result (the </> button).
Then show us what it is in FME you did with a view on all headers that you added and the exact json body.
And then we can take it from there again 😉
itsmatt
Forum|alt.badge.img+48
  • May 5, 2024 11:00 AM UTC
Could it be as simple as the URL is wrong?
I just notice in FME the record used in the URL resolves to  "PINELLAS-24CAP-00000-0004H" but in potman it looks like you have:
"24CAP-00000-0004H"
(i.e., without the PINELLAS-)?
I'm not at all familiar with the API but this was something that I noticed.
missp29
  • May 8, 2024 3:14 PM UTC
@virtualcitymatt
They are the same. The API can take either of them.
@tva
As you suggested, I did run the test on both integer 1 and string “1”. Both gave me the same error.
In addition, I did figure out a workaround and am able to call the API successfully.
Here is how I did originally. Below is a screenshot of part of the FME Form. I have a AttributeManager transformer which provides data for the API call. Before I make the call to the API, I use a JSONTemplate transformer to construct the request body for the API. The right part of the screenshot is the request body which is generated from the JSONTemplate transformer. Also I have a screenshot of the HTTPCaller parameters. As you see, I only have a single attribute Authorization defined there. This approach doesn’t work.
here is my workaround as shown below.
All I did is to remove the JSONTemplate transformer and directly construct the request body in the HTTPCaller transformer. As shown in the screenshot, the syntax in the request body is different from the one generated from the JSONTemplate. This approach does work.
I still have no ideas why the first approach doesn’t work. To me, from HTTPCaller perspective, both approaches should not have any differences. Maybe there are some hidden things I cannot see them.
Thanks,
-John
tva
  • May 8, 2024 5:21 PM UTC
Hi @missp29 indeed jsontemplater or directly in httpcaller should not matter.
Can you show us a screenshot of the output from the json templater?  It might be bracket related.
And about the id being an int or string, even in postman it doesn't matter?
missp29
  • May 9, 2024 1:19 PM UTC
Hi @tva
here is a screenshot of the output from the JSONTemplate.
I even tried to copy the data directly into the JSONTemplate. That still gave me the error.
Thanks,
-John
