Resize Image without degradation
  • Nov 5, 2019 8:52 PM UTC
  • 6 replies
  • 767 views
philippeb
Forum|alt.badge.img+23
Hello,
I want to resize an image. Per example 1000*1000 pixels to 200*200 pixels.
I tried RasterResampler, but I only get a degradation of the image, with the same size.
Is there a way to do that?
This is not my family : legacy from Google Images.
In M$Paint I would use this.
Best answer by daveatsafe
Hi @philippeb,
Please set the Interpolation Type in the RasterResampler to Bicubic. This setting gives the best results for photos. The default Nearest Neighbor works best on elevation models.
Please note that the extents of the image in Data Inspector will not change, since the georeferencing was created when the image was read, and is not changed by the resampling. The pixel spacing will change to reflect the new pixel size, though. This georeferencing will be discarded if you write out to a non-geographic format, like PNG, JPG or TIFF.
daveatsafe
Forum|alt.badge.img+24
  • Nov 5, 2019 9:15 PM UTC
Hi @philippeb,
philippeb
  • Nov 5, 2019 9:38 PM UTC
Hi @philippeb,
Good, it works perfectly with JPEG. Do you think it would be possible to write the resized image into a 3D PDF ?
daveatsafe
  • Nov 5, 2019 10:04 PM UTC
Sure - just use a FaceReplacer transformer to convert the image to a Face textured with that same image, which is suitable for writing to 3D PDF.
philippeb
  • Nov 6, 2019 7:37 PM UTC
resizedimageinto3dpdf.fmw
Hi @daveatsafe
So I'm now able to write an image into 3D PDF. I just learned another transformer. Thank you :)
But when I resize the image, it only degrades the quality. Nothing else is happening, as you can see.
This is my workbench, but I put it in attachment.
daveatsafe
  • Nov 6, 2019 10:39 PM UTC
Hi @daveatsafe
Hi @philippeb,
Whenever an image is created or read into FME, it is is given a georeference to tie it the world. If this cannot be read from the source data, a default georeference is created, with 0,0 at the upper left corner of the image and a pixel size of 1.
Resampling the image will change the number of pixels in the image, but not the georeference location of the image. This is good if you are creating a lower resolution aerial image, since the image corners remain in the same location.
If you want to change the extents of the image as well as the resolution, you can use the Scaler transformer after the RasterResampler, with the X and Y scale factors set to 0.2, and Z Scale left at 1.
philippeb
  • Nov 7, 2019 2:07 PM UTC
Hi @philippeb,
A Scaler before FaceReplacer, exactly what I needed! Thanks a lot!!
