Rename image file name to match data in spreadsheet
  • May 28, 2021
  • 108 views
I have hundreds of image files that require renaming.
I have an Excel sheet with the oringinal file names in one column and in another colomn the prefered file name. I would like to replace the image file (.jpg) name with the new name the column in the spreadsheet. I found an article on how to do this, but I can't seem to get the script to work. I am new to FME. I have provided the workbench file and the spread sheet and a image file.
Can some one please help guide me with where I am going wrong?
nielsgerrits
Forum|alt.badge.img+54
I always find the FileCopy Writer not as intuitive as most other FME components and really need to dive in to get it working. As an alternative I prefer to use the SystemCaller transformer to do this with commandline:
rename "@Value(current_filepath)" "@Value(new_filename)"
so you get something like
rename "C:\Temp\New folder (4)\files\old.txt" "new.txt"
for each file.
2021-05-28_06h17_48Added a sample workspace demonstrating this. I prefer to doublecheck and the commandline manually before running it all through the SystemCaller.
