Removing Duplicate values from the column
parashari
Hi, I have a column 'Flag', where there are duplicate values seperated by '_&_' and I want to remove the duplicate values from it. I tried using the AttributeSplitter and creating Lists, but seemed to be too long. Can we do it with some other way? May be regex or list or something new?
Best answer by takashi
Hi @hellblazer, have you tried a chain of AttributeSplitter, ListDuplicateRemover and ListConcatenator?
  • April 19, 2018
parashari
  • April 20, 2018
That really works for me.
But, when I see the output of AttributeSplitter and ListDuplicateRemover, no difference is visible, but suddenly the required out is displayed. I am guessing we are creating a list first (AttributeSplitter), removing the duplicates (ListDuplicateRemover) and then concatenating the required results with a seperator (ListConcatenator). Is it?
Where all can we use these combinations or other such combination?
Well, thanks for a quick help @takashi :)
  • April 20, 2018
Yes, your observation is correct. That's the procedure exactly I intended.
