Remove folders with System Cleanup
  • Nov 10, 2017 10:00 AM UTC
  • 156 views
zzupljanin
Forum|alt.badge.img+5
In System Cleanup on FME Server UI you can set tasks do remove files (in Source Folder) older than some amount.
Does it delete all subfolders in that given Source Folder?
Best answer by richardatsafe
Hi @zzupljanin,
It does delete the sub folders. For instance the Delete_Job_logs tasks will delete all the jobs and the automatically created sub folders. Was there a specific task or circumstance in which you wanted different behaviour?
richardatsafe
Forum|alt.badge.img+11
  • Nov 10, 2017 7:21 PM UTC
Hi @zzupljanin,
zzupljanin
  • Nov 23, 2017 5:28 AM UTC
Hi @zzupljanin,
Confirmed. It does delete subfolders...
