Remove filed without values
Hi
I need to reformat some csv file (so rename use conditional value ecc ecc) but at the end I want also to remove the fields that are empty (I mean every fields without any value inside)
thx
Francesco
philippeb
Forum|alt.badge.img+21
  • July 19, 2018
Try the AttributeValidator for your fields.
xiaomengatsafe
Forum|alt.badge.img+10
Hi @frsisani, This might not be as straight forward as it seems at first glance. Luckily we've had people asking similar questions before. So, check out this Q&A; thread "Remove Empty Fields". I think you might find some answers helpful. Thanks!
