Remove extra vertices and retain geometry (Line)
galigis
Forum|alt.badge.img+20
Hi All,
I’m trying to create a 10m node line from a 2.5m node line. I have tried ‘Densifier’, ‘Line Combiner’ and also ‘Chopper’ but can’t get it to work,
How can I reduce the number of vertices and to obtain a 10m node line?
Thanks
Best answer by nielsgerrits
  • Densifier 10 meter.
  • Chopper 10 meter.
  • Generalizer to remove all points except start & end.
  • LineCombiner to reconnect all lines.
nielsgerrits
Forum|alt.badge.img+54
  • March 6, 2025
  • Chopper 10 meter.
galigis
  • March 10, 2025
Thanks ​@nielsgerrits  - your suggestion has worked perfectly :)
Below an screenshot of the workflow for completeness:
