Regular Expression to extract the earliest year from Attribute
  • Nov 9, 2017 12:09 PM UTC
  • 6 replies
  • 95 views
I have the following string in an attribute: "Jan 1 1960; Jan 1 1900; Jan 1 1960; 01/05/1890; Jan 1 1960; Jan 1 1960; Jan 1 1960; Jan 1 1960; Jan 1 1960; Jan 1 1960; " I need to extract the earliest year from the attribute, since this is input from a reader the attribute will have different values, but the year will always be in a 4 digit format. I want to use a regular expression to extract the earliest year, in this case it would be 1890. Is this possible?
Best answer by david_r
Here's one way:
  • StringSearcher with a regex like "\\d{4}" to extract all occurrences of 4 consecutive digits. Specify a list name for all the "All matches list name"
  • ListSorter in ascending numerical order on the match list
  • ListIndexer on item 0 to extract the lowest number
Example:
  • Nov 9, 2017 12:13 PM UTC
Here's one way:
Example:
  • Nov 9, 2017 12:56 PM UTC
Here's one way:
Example:
Thanks for your answer David. I'm Using FME 2016, the ListSorter transformer doesn't have the defined list in StringSearcher available.
Forum|alt.badge.img+54
  • Nov 9, 2017 1:01 PM UTC
It should be there if you expand the Advanced part
  • Nov 9, 2017 1:05 PM UTC
Here's one way:
Example:
In FME 2016 I've used the Subexpression Matches List Name which makes the list available to the ListSorter
  • Nov 9, 2017 1:30 PM UTC
FME 2016 and 2017 are identical on this point, you need to specify the "All matches list name", not the "Subexpression matches list name" (there are no sub-expressions in this regex).
  • Nov 9, 2017 1:56 PM UTC
Just for fun. Sometimes FME can solve a puzzle with a collaborative work of string/math operations and geometric operations.
Set OGC Well Known Text to the Geometry Encoding parameter, and set this expression to the Geometry Source parameter in the GeometryReplacer
LINESTRING(@Trim(@ReplaceRegEx(;@Value(text),";.+?(?=\d{4})",",0 "),",; "))
