RegEx for null or empty attributes
  • November 15, 2012
  • 3381 views
What RegEx can I use to define null or empty attributes in StringReplacer? Or do I even need to use RegEx? I'm trying to replace null/empty attributes with UNKNOWN. Seems simple enought but it's giving me fits.
Best answer by casey
Both suggestions work great! Thank you for the quick responses.
  • November 15, 2012
You can use a Tester and set the the operation to Attribute Is Null followed by AttributeSetter
-Sean
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • November 16, 2012
A Tester->AttributeSetter would work as Sean suggested.
Be aware that there's an al-in-one NullAttributeReplacer transformer that likewise performs what you are after.
  • November 16, 2012
fmelizard
Forum|alt.badge.img+22
  • November 18, 2012
To answer the original question, an expression of "^$" (without the quotes) should match an empty string. It sounds like the NullAttributeReplacer might be more appropriate here, though.
