Recreate raster but with smaller cell size
  • Apr 27, 2020 9:57 AM UTC
  • 13 replies
  • 196 views
harmen_kampinga
Simple need, simple question.
I have a raster with 1 cell size 25x25 meters (geotiff)
Just want to have the cell split up to a 5x5 meters raster with having those new 25 cells with a 5x5 meters raster having the same value as the original 1 cell of 25x25 meters
And nothing else should change! But whatever Transformer I use or in combination with each other, it doesn't let me succeed in my goal.
For example: with the RasterResampler it recreates a new raster with my desired resolution, but it doesn't keep the original values. It also seems to shift my raster.
I have also tried to create a new raster and then use the points from that raster to extract the desired values. But that takes so much time to process...
What am I missing? What do I not understand?
harmen_kampinga
One thing can mess the RasterResampler, that is having some projection and/or coordinate system attached to the raster. In my case, it was an XML file containing the details.
So having no file attached, but with a bare GeoTIFF file (containing a coordinate system) I have tried it again, but it's still not working as expected...
jdh
Forum|alt.badge.img+41
  • Apr 27, 2020 1:37 PM UTC
A RasterResampler with the Interpolation Type set to Nearest Neighbour should do what you want.
If it's not working in your projected data, you can use a BoundsExtractor, remove the the georeferencing information (RasterGeoreferencer (0,0,1,1,0), CoordinateSystemRemover , and then resample from 1 to 0.2, and the use the another RasterGeoreferencer in Extents mode with the values from the BoundsExtractor to restore the original position. CoodinateSystemSetter set the projection.
harmen_kampinga
Thanks @jdh for your response!
It makes sense to do so. Unfortunately, I still have those weird shifting results. Can't figure it out...
jdh
  • Apr 27, 2020 2:40 PM UTC
What kind of shifting is going on?
harmen_kampinga
Well, it seems that overall the raster is shifting in the direction of the arrow.
Tried to correct that in earlier versions of my workspace with the RasterCellOriginSetter , unfortunately without success.
jdh
  • Apr 27, 2020 3:30 PM UTC
Is it half a pixel? Or is it a rounding error? If you are using a format with a world file, FME might truncate the precision.
harmen_kampinga
It's a shift of about 5 meters
No, I have no world file or so attached, it's in the GeoTiff
harmen_kampinga
I you like, I can send the GeoTiff to you :-)
harmen_kampinga
So, when I add the RasterCellCoercer and visually compare the points with the raster, you'll see this: the points are not aligned with the raster itself. That has somehow to do with the projection I use.
Can't get it right.
Very frustrating.
jdh
  • Apr 27, 2020 4:22 PM UTC
Can't get it right.
Very frustrating.
Is there a rotation on the raster?
harmen_kampinga
No, unfortunately not
Hereby you see the properties from the raster
jdh
  • Apr 27, 2020 4:59 PM UTC
I'm not familiar with the Amersfoort projection. If you remove the coordinate system from the original raster, then resample, do the two rasters line up in the inspector (if the rasters are large, I often just use a boundingboxreplacer to get the footprint in the inspector)
harmen_kampinga
Well, I'll have a look at it... at the moment I'm accepting the issue as is. Just to see how my workspace overall works... it's time to have that tested first (because of a deadline ;-) )
I will get back on this issue, asap. Want to understand what's going on...
Thanks @jdh for your support till now!
