Reading shapefile attributes with Python Creator
  • Oct 20, 2023 12:23 PM UTC
  • 177 views
marketa
Hello,
I am trying to use Python Creator to read a shapefile from user parameter input file and expose all the attributes to be able to use the data later in the workflow. Is it possible to do it?
The reason of not using shapefile Reader is that the attributes of multiple input shapefiles can differ. The goal of the FME is to import the shapefiles into a database (the final DB table attributes must be equal to the attributes of input shapefile).
Thank you.
dustin
Forum|alt.badge.img+36
  • Oct 20, 2023 12:30 PM UTC
A dynamic workflow is what you are looking for. You can find extensive discussion on that topic at this link: https://community.safe.com/s/article/dynamic-workflow-tutorial-basics-of-dynamics
  • Oct 20, 2023 12:32 PM UTC
You can only expose attributes at design-time, not at run-time.
The solution is to use dynamic schema in FME, here is a good starting point: https://community.safe.com/s/article/dynamic-workflow-tutorial-introduction
marketa
  • Oct 20, 2023 12:35 PM UTC
Thank you for your answers!
