I have FeatureReader transformers within my workspace that are configured to read features from an Excel file.
The name and path of the Excel file are variables provided by parameter values, but the Excel sheet name is always the same. The schema of the file is likely to vary every time the workspace is run.
I'm really struggling to get any features to read in, and am a bit unsure of where I'm going wrong. From similar posts in the past (eg; https://community.safe.com/s/question/0D54Q000080hdRJSAY/how-to-expose-attributes-from-featurereader-if-feature-type-is-dynamic) it seems that what I'm trying to do potentially isn't possible without scripting something bespoke in a PythonCaller, but it really seems like something that FME should be able to do.
Does anyone have any advice or a working methodology for this sort of problem? Thanks in advance
