Read PostGIS database schema from Database using Published parameter
  • Mar 13, 2020 4:52 AM UTC
  • 55 views
parashari
Hi. I am working with FME 2019.1 and I have created a workbench that needs to be run by a person new to FME.
The wb uses PostGIS database where the connection details are 'Embed Connection Parameters'. There are multiple hosts which come as dropdown options (choice parameter). So, when I have select a database from the dropdown, next thing is the schema that should be reading/loading by itself of the selected host. But, that's not coming.
What is now-
Problem faced: It is done manually by copying the schema name from PostgreSQL server to FME. Any ideal solution for this?
Thanks.
Forum|alt.badge.img+63
If you use a FeatureReader rather than a PostGIS reader you'll have some more liberty in prepping the parameters, I think that might come in useful for you.
