Read CSV File and split the content into lines and columns
dataman
Hey there,
I have to download several CSV Files from a website. I do it with the HTTPCALLER Transformer. It works perfect. I get ALL the data (several columns and lines) in one "cell":
imageI need the informations in lines and columns, so that I can manipulate the data.
I have tried with Pythoncaller, ListExploder, AttributeCreator,... but it doesn't work.
Do you have any idea, how can I get that? I think the problem is the configuration of the HTTPCALLER or of the other Transformers but I have tried a lot of things and nothing works.
Many thanks in advance!
Best answer by nielsgerrits
Multiple ways:
  • Writing and reading as a file. Will cost some I/O, but is probably the fastest. You can write to temp files to avoid having temp files to clear afterwards using the TempPathnameCreator. This is the way I prefer.
    • Write as CSV using a FeatureWriter.
    • Write as CSV from HTTPCaller.
    • Read written file using a FeatureReader.
  • Splitting the attributes to a list. Create attributes from listelements.
    • Split file to lines based on newline.
    • Split lines to columns based on semicolon.
    • Create attributes from listelements.
Forum|alt.badge.img+55
  • July 18, 2023
Multiple ways:
Forum|alt.badge.img+39
  • July 18, 2023
nielsgerrits wrote:
Multiple ways:
No need for the FeatureWriter, you can choose save response body to file instead of attribute in the http caller
nielsgerrits wrote:
Multiple ways:
Attached workspace demonstrating this.
dataman
  • July 18, 2023
thanks for the answer. If I save the URL as CSV with the featurewriter and after that I read it as featureReader, it goes so fast, that the informations won't be as attribute read... I suppouse that the reader is too fast and the file was not saved
dataman
  • July 18, 2023
nielsgerrits wrote:
Multiple ways:
The second way works perfect. Awesome! thanks
You need to expose the attributes manually, or using import.
Cheers :)
