Query A Date Field To Only Return <=90 Days From Current Date
  • April 18, 2017
  • 5 replies
  • 167 views
ngstoke
I'm trying to develop a workbench that will only return records from Excel spreadsheets that are within 90 days from the current date when I run the workbench. I'd like to not have to enter the current date every time I run the workbench. Is there an expression I can use or a transformer to perform this.
Any help is greatly appreciated.
My dates are formatted as seen below.
20170525
20170624
20170708
20170902
Best answer by ciarab
dates.fmwt
Hi @ngstoke
you should be able to do this using relative dates and testing your dataset using a tester to extract your data that is within 90days of your request. I have attached a sample workflow that you can review
dates.fmwt
ciarab
Forum|alt.badge.img+10
  • April 18, 2017
dates.fmwt
Hi @ngstoke
dates.fmwt
erik_jan
Forum|alt.badge.img+26
  • April 18, 2017
Use the TimeStamper transformer to get the current date and feed that to the FeatureReader to read the data based on that date. You need to trigger the TimeStamper with a Creator transformer.
ngstoke
  • April 18, 2017
dates.fmwt
Hi @ngstoke
dates.fmwt
Thank you @ciarab I was able to modify your workflow and get the answers I was after.
Much appreciated
Hi @ngstoke
are you using FME 2017? With FME 2017 new datetime functionality, your workflow can be as simple as this:
If you are working with FME 2017.0 you will only have old TimeStamper - which will still do the job for you. In FME 2017.1 we have added new DateTimeStamper which is more powerful and user friendly. You can download FME 2017.1 beta from https://www.safe.com/support/support-resources/fme-downloads/beta/
gio
Forum|alt.badge.img+15
  • April 19, 2017
@ngstoke
You can of course do it in a single transformer, just bit of tcl datecalcing needed...
In a tester test for
@abs(
[clock format [clock scan today] -format {%j}] - [clock format [clock scan {YourAttribute}] -format {%j}]
)<=90
Format you posted is basic format for cloc scan.
-format %j is days counting in 3 digits (which you could also use as input if needed )
