Q: Find missing number from sequence of column data
  • Oct 5, 2021 7:35 AM UTC
  • 92 views
Hi there, so I have two column of data.
The column "Test_FloorNumber_Begin0" should have sequence of 0000, 0001, 0002, 0003 - the largest number of the input, or 0999.
The second column "Test_FloorNumber_Begin1" should have sequence of 1000, 1001 - the largest number of the input, or 1999.
The sequence should start from 0000/1000 to the largest number from the input data.
So I want to use FME to find out the missing number and output it. In this case 0000 to 0003 and 1002-1003 are missing.
Please help me as I want clueless on how to work this out.
Thank you very much.
danilo_fme
Forum|alt.badge.img+58
  • Oct 5, 2021 12:31 PM UTC
Hi @zacharylee1204​
The PythonCaller transformer is good in this case.
In the Workspace template ( FMWT ) there are 2 transformers PythonCaller - each attribute:
gapsResult in Data Inspector:
Result
Thanks in Advance,
Danilo
Hi @zacharylee1204​
Result
Thanks in Advance,
Danilo
I will try it later today. Thank you very much! :)
