PythonCaller Transfromer and Multiprocessing
  • Jan 10, 2021 5:03 PM UTC
  • 154 views
I'm struggling with the PythonCaller Transfromer regarding multiprocessing. The script below is a simple example to illustrate my problem. How can I get it running as a PythonCaller script? Currently the translation log says:
File -c could not be opened
Program Terminating
Translation FAILED.
Error running translation.
Translation Aborted
import multiprocessing
import random
import time
def worker(t, i, return_dict):
    print("Sleep {} seconds".format(t))
    return_dict[i] = t
    time.sleep(t)
def multiprocessing_test(n):
    print("in multiprocessing_test")
    manager = multiprocessing.Manager()
    return_dict = manager.dict()
    jobs = []
    for i in range(n):
        p = multiprocessing.Process(target = worker, args=(random.randint(3,6), i, return_dict,))
        jobs.append(p)
        p.start()
    for p in jobs:
        p.join()
    print(str(return_dict))
if __name__ == "__main__":
    def processFeature(feature=None):
        print("in processFeature")
        multiprocessing_test(10)
    #processFeature() # Uncomment to test the script with the python interpreter outside of FME. Output is:
# in processFeature
# in multiprocessing_test
# Sleep 4 seconds
# Sleep 6 seconds
# Sleep 3 seconds
# Sleep 6 seconds
# Sleep 6 seconds
# Sleep 4 seconds
# Sleep 6 seconds
# Sleep 5 seconds
# Sleep 6 seconds
# Sleep 6 seconds
# {0: 4, 8: 6, 3: 6, 2: 3, 5: 6, 1: 4, 7: 6, 9: 5, 4: 6, 6: 6}
Best answer by __alex__
Maybe the answer by @jeroenstiers on the question below may concern your question?
https://community.safe.com/s/question/0D54Q000080hL2TSAU/are-features-ran-through-pythoncaller-sequentially-or-with-multithreading-
__alex__
Forum|alt.badge.img+5
  • Jan 12, 2021 9:12 AM UTC
  • Jan 12, 2021 9:29 AM UTC
What I don't like about this solution is that stdout and stderr are only displayed in the translation log after the script has finished and not during the script. If the script runs for a long time it might seem as the process got stuck. But it is better than doing it without multiprocessing.
  • Jan 14, 2021 3:30 PM UTC
Can you flip the problem on its edge? As in, can you let FME handle the multiprocessing and Python handle the processing? I.e. making a custom transformer with just a PythonCaller (and whatever else is needed) inside it. That way, you at least get the parallellism, but still sequential within the group.
