Python error for DateTimeCalculator
  • Feb 3, 2020 4:22 PM UTC
  • 42 views
jhu_20
Forum|alt.badge.img+12
I have old workspace and received the following Python error message after upgraded to FME 2019.2 and didn't install any Python 2.x. Any suggestion for getting around the issue ? Thanks.
Python Exception <NameError>: name 'unicode' is not defined
Traceback (most recent call last):
File "<string>", line 26, in input
NameError: name 'unicode' is not defined
Error encountered while calling method `input'
DateTimeCalculator_2_PythonCaller (PythonFactory): PythonFactory failed to process feature
Forum|alt.badge.img+54
  • Feb 3, 2020 4:28 PM UTC
Is this the custom "DateTimeCalculator"? If so, the best way forward would be to replace with the native DateTimeCalculator
There is information here about the change that needs to be made to avoid the python error if for some reason you need to keep the custom transformer
https://hub.safe.com/publishers/pacific-spatial-solutions/transformers/datetimecalculator#comments
