PYTHON Cross and Dot product function with logic with Directional Vector??
  • Dec 8, 2023 11:01 AM UTC
  • 7 replies
  • 93 views
vimva679
Forum|alt.badge.img+11
Hello
It says Translation is Successful, but i dont't see the any out , am i doing something horribly wrong or missing some setup ?
imagePython Caller
import fme
import fmeobjects
import numpy as np
class FeatureProcessor(object):
def __init__(self):
pass
  def input(self, feature):
    def myfunction(L, F, DX, DY, DZ):
      DLF = [0,0,-1]
      ULF = [0,0,1]
      NLF = [0,1,0]
      SLF = [0,-1,0]
      ELF = [1,0,0]
      WLF = [-1,0,0]
      if L == "D":
        UAP = DLF
      elif L == "U":
        UAP = ULF
      elif L == "N":
        UAP = NLF
      elif L == "S":
        UAP = SLF
      elif L == "E":
        UAP = ELF
      elif L == "W":
        UAP = WLF
      if F == "D":
        FAP = DLF
      elif F == "U":
        FAP = ULF
      elif F == "N":
        FAP = NLF
      elif F == "S":
        FAP = SLF
      elif F == "E":
        FAP = ELF
      elif F == "W":
        FAP = WLF
      VAP = np.cross(FAP, UAP)
      DU,DV,DN = np.linalg.inv(np.column_stack((UAP, VAP, FAP))).dot(np.array(DX,DY,DZ))
      return DU,DV,DN
      self.pyoutput(feature)
  def close(self):
    pass
import fme
import fmeobjects
import numpy as np
    def __init__(self):
        pass
        feature = myfunction(L, F, DX, DY, DZ)
    def close(self):
        pass
        DLF = [0,0,-1]
        ULF = [0,0,1]
        NLF = [0,1,0]
        SLF = [0,-1,0]
        ELF = [1,0,0]
        WLF = [-1,0,0]
        if  L == "D":
            UAP = DLF
        elif L == "U":
            UAP = ULF
        elif L == "N":
            UAP = NLF
        elif L == "S":
            UAP = SLF
        elif L == "E":
            UAP = ELF
        elif L == "W":
            UAP = WLF
        if F == "D":
            FAP = DLF
        elif F == "U":
            FAP = ULF
        elif F == "N":
            FAP = NLF
        elif F == "S":
            FAP = SLF
        elif F == "E":
            FAP = ELF
        elif F == "W":
            FAP = WLF
        return L,F,DX,DY,DZ,DU,DV,DN
  • Dec 8, 2023 12:09 PM UTC
When posting Python code, can you please apply the Code Snippet formatting to make it more readable.
That said, why are you declaring a function "my_function" inside the input method, and then never calling it?
vimva679
  • Dec 8, 2023 12:16 PM UTC
@david_r​ tnx for your reply, this is my first python code and am learning so not so much sure, how to get the code snippet formatting. I just copied and pasted from PythonCaller. However i have attached the FME workbench above.
Forum|alt.badge.img+63
imageYou can use that button on a selected piece of text
To create a code snippet
(and on a general note, a little bit more info in the title of your post would make it easier for people browsing the list of topics to see what it's about)
vimva679
  • Dec 8, 2023 12:31 PM UTC
@Hans van der Maarel​ :) thank you some new learning today
  • Dec 8, 2023 12:57 PM UTC
Try the following (untested). Be careful to preserve indents. I'm assuming that the incoming attributes DX, DY and DZ are simple numbers (int or float), the code needs modification if that is not the case.
import fme
import fmeobjects
import numpy as np
    def __init__(self):
        pass
        # Retrieve FME feature attributes into Python attributes
        L = feature.getAttribute('L')
        F = feature.getAttribute('F')
        DX = float(feature.getAttribute('DX'))
        DY = float(feature.getAttribute('DY'))
        DZ = float(feature.getAttribute('DZ'))
        # Call our function
        L, F, DX, DY, DZ, DU, DV, DN = myfunction(L, F, DX, DY, DZ)
        # Set FME feature attributes based on return values
        feature.setAttribute('L', L)
        feature.setAttribute('F', F)
        feature.setAttribute('DX', DX)
        feature.setAttribute('DY', DY)
        feature.setAttribute('DZ', DZ)
        feature.setAttribute('DU', DU)
        feature.setAttribute('DV', DV)
        feature.setAttribute('DN', DN)
    def close(self):
        pass
    DLF = [0,0,-1]
    ULF = [0,0,1]
    NLF = [0,1,0]
    SLF = [0,-1,0]
    ELF = [1,0,0]
    WLF = [-1,0,0]
    if  L == "D":
        UAP = DLF
    elif L == "U":
        UAP = ULF
    elif L == "N":
        UAP = NLF
    elif L == "S":
        UAP = SLF
    elif L == "E":
        UAP = ELF
    elif L == "W":
        UAP = WLF
    if F == "D":
        FAP = DLF
    elif F == "U":
        FAP = ULF
    elif F == "N":
        FAP = NLF
    elif F == "S":
        FAP = SLF
    elif F == "E":
        FAP = ELF
    elif F == "W":
        FAP = WLF
vimva679
  • Dec 8, 2023 1:10 PM UTC
import fme
import fmeobjects
import numpy as np
    def __init__(self):
        pass
        # Call our function
    def close(self):
        pass
    DLF = [0,0,-1]
    ULF = [0,0,1]
    NLF = [0,1,0]
    SLF = [0,-1,0]
    ELF = [1,0,0]
    WLF = [-1,0,0]
    if  L == "D":
        UAP = DLF
    elif L == "U":
        UAP = ULF
    elif L == "N":
        UAP = NLF
    elif L == "S":
        UAP = SLF
    elif L == "E":
        UAP = ELF
    elif L == "W":
        UAP = WLF
    if F == "D":
        FAP = DLF
    elif F == "U":
        FAP = ULF
    elif F == "N":
        FAP = NLF
    elif F == "S":
        FAP = SLF
    elif F == "E":
        FAP = ELF
    elif F == "W":
        FAP = WLF
vimva679
  • Dec 8, 2023 1:48 PM UTC
@david_r​  got it
YAHOO>>>>>>first FME Python code ...now working thank you David image
