Processing OS ITN data for use in ESRI's Network Analyst
  • Apr 7, 2016 5:13 PM UTC
  • 84 views
I want to generate a service area using Ordnance Survey's ITN Roads and ITN Urban Paths data. I have a licence for Esri's Network Analyst, but not for their Productivity Suite, which would allow me to convert the data into something that Network Analyst can use. Is there any way I can convert the ITN data using FME or to be able to perform this analysis using FME?
Many thanks
mark2atsafe
Forum|alt.badge.img+59
Hi
It's certainly possible to read ITN data with FME. I just downloaded the demo dataset to try it out.
There are lots of options from there. You could convert the data into Geodatabase - for example - for loading into Esri tools.
There are also FME transformers for networks, such as the ShortestPathFinder and the NetworkCostCalculator. The NetworkCostCalculator is what I believe you might use to 'generate a service area', though I'm not really sure what that means exactly.
In short - yes you can convert or use this with FME. For more information please do follow up here, or contact our support team who would be glad to help (http://www.safe.com/support) and might even be able to set up a demo for you.
Hope this helps
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
  • Apr 8, 2016 7:23 PM UTC
Hi
Hope this helps
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
FME Reads ITN just fine - but there'll need to be some additional processing to build the full network into the required output format e.g. turn restrictions, one way streets etc.
