Problem with write PDF 2D
danilo_fme
Forum|alt.badge.img+45
Hello,
I have 4 feature types and i use the transformer PDFPageFormatter to configurate my PDF output.
The problem is when write this Output ( attached ) the feature types didnt write exactly like FME DAta Inspector. How can i do this configurated well?
The output wrong in PDF:
Attached my template file.
Thanks
Best answer by redgeographics
The PDFPageFormatter will fill the paperspace with the data you put in it. So data with smaller extents will get more zoomed in. You should put everything into one PDFPageFormatter input, that way they will be (if they're in the same coordsys) overlayed properly. Controlling the order of the objects can be done by sorting on an attribute.
To me this is logical behaviour, every paper space is a "map" by itself (the software I use for my map production has a similar concept)
pratap
Forum|alt.badge.img+11
  • December 6, 2016
Do you want as Layer in PDF? If yes have you tried fanout?
Pratap
danilo_fme
  • December 6, 2016
pratap wrote:
Pratap
Hello @pratap, i just want to write pdf correct like the screen
I believe is the error is inside the transformer PDFPageFormatter.
Thanks
pratap
  • December 6, 2016
Due to version conflict, I cannot open your workspace. Just remove the PDFPageFormatter and try migrating directly to pdf. If it goes fine then the problem is related to PDFPageFormatter.
gio
Forum|alt.badge.img+15
  • December 6, 2016
@danilo_inovacao
Yoo have to align the geo- extents of the objects in the pdf.
You could grab the boundingbox for that. Boudingboxaccumulator for example.
There are a couple of examples on this issue n this forum.
(I should know, because I complained about this lack of auto-alignement..;))
It is indeed a manco of the pdf_pageformatter, you can't just drag in some paperspaces. They must align and have same aspectratio in the pdf. ( see readers and writers on pdf.: pageframe and worldframe) Fme 2016 still has this issue...
couple of days ago I made a post on getting foto's align with a border in pdf pages , look it up. Basically same issue
Forum|alt.badge.img+49
  • December 7, 2016
