Problem with minimun and maximum value of raster
  • November 28, 2019
  • 5 replies
  • 76 views
marta
I have a problem with maximum and minimum value of raster. I have a script (on screenshot, and attached) that calculates NDVI.
Firstly I use RasterExpressionEvaluator to count NDVI, and then RasterBandMaxMinExtractor to extract max and min (I need those for further calculation). The maximum and minimum I get are different then maximum and minimum in QGIS for the same raster file.
I checked raster before I run RasterExpressionEvaluator, and minimums, and maximums of bands are the same in FME, and QGIS, so I think the issue might be with the RasterExpressionEvaluator, but I am not sure.
Has anyone has idea how to get this issue right? I need proper max and min value for normalization of NDVI, and I can see that results I get with this max and min value are wrong.
daveatsafe
Forum|alt.badge.img+19
  • November 28, 2019
Hi @marta,
What are the min/max values produced by FME and QGIS, for comparison?
marta
  • November 28, 2019
daveatsafe wrote:
Hi @marta,
Hi @daveatsafe
FME says:
_band{0}.max (string): 0.6461538461538462
_band{0}.min (string): -0.4368932038834951
QGIS says:
Maximum:0.346939
Minimum:-0.283019
The difference is too big, and when I use max/min from FME to normalize (change the range to -1,1) the raster the output is terrible.
Thanks for quick reply!
becchr
Forum|alt.badge.img+26
  • November 29, 2019
Hi @marta, no idea what your source image is, but as far as i used them before the bands of a three-band CIR color-infrared images are in order: near infrared, red and green. So could it be your expression should be (A[0]-A[1])/(A[0]+A[1])?
And for your interest: there's a NDVI custom transformer in the hub I used before with satisfaction, maybe you could check the results with that transformer too?
marta
  • November 30, 2019
Thanks @becchr for answer. I changed the bands, and used this NDVI custom transformer, but still has the same problem. I get raster from FME, and FME says max is about 0.68, min -0.44, and GQIS max about 0.65, and min -0.22
daveatsafe
  • December 6, 2019
marta wrote:
Hi @daveatsafe
FME says:
QGIS says:
Maximum:0.346939
Minimum:-0.283019
Hi @marta,
I tested your workspace with a sample image and QGIS 3.4, but was not able to reproduce the problem. Would you be able to share a sample of your source imagery with me? If you don't want to make it public, you can send it to me directly:
