Problem overlapping lines in DWG File
  • Feb 12, 2019 4:22 PM UTC
  • 8 replies
  • 171 views
arxit
Forum|alt.badge.img+5
Hello,
I have a problem to find overlapping lines with FME, in a DWG file :
If there are common vertices between lines, SpatialRelator (or SpatialFilter) works.
Wheareas, if there is no common vertex, overlaps are not found.
I tried LineOnLineOverlayer, Intersector and TopologyBuilder, but They have not fixed the problem.
I read these articles, but I didn't find a solution :
https://knowledge.safe.com/questions/1633/intersector-overlap-issue.html
https://knowledge.safe.com/questions/58290/find-overlapping-lines-in-network.html
Is there another solution to do this ?
Thank you.
Best answer by gio
@arxit
That is because the line do not have same function. ..and do not intersect.
Check their angles, they differ after the 10 decimal.:
Angle
6.024405345316602
6.024405345377287
As @egomm said if you use a tolerance in the LineOnLineOverlayer (0.000000001 or larger works..)
you get your expected result.
(You could also round the coordinates, extend the lines, sync the angles, unify the functions etc.)
Forum|alt.badge.img+54
  • Feb 12, 2019 4:31 PM UTC
Did you have a tolerance set in the intersector?
arxit
  • Feb 12, 2019 4:35 PM UTC
I attach a DWG File, only with 2 lines, where the SpatialRelator don't find overlap between them : drawing2.dwg
arxit
  • Feb 12, 2019 4:40 PM UTC
No tolerance in the intersector
  • Feb 12, 2019 4:44 PM UTC
You didn't set a tolerance, or you don't have that option? With the current version of the intersector, those overlapping segments are found if a tolerance is set
gio
Forum|alt.badge.img+15
  • Feb 12, 2019 4:47 PM UTC
@arxit
Angle
6.024405345316602
6.024405345377287
arxit
  • Feb 12, 2019 5:18 PM UTC
@arxit
Angle
6.024405345316602
6.024405345377287
Yes, it works with a tolerance in the Intersector.
however I tried with a CoordinateRounder before the SpatialRelator, but it don't find Overlaps.
arxit
I didn't set a tolerance
arxit
  • Feb 12, 2019 5:30 PM UTC
Thank you, it works with a tolerance
