PostGIS polyhedral surface from solid
  • March 16, 2017
  • 138 views
j_geo
Hello,
I have a problem with writer to postgis.
I make one solid in FME with SolidBuilder. Then I write it to PostGIS
as polyhedral surface.
The problem is, that when I read the same object from PostGIS into
FME and make solid again with SolidBuilder, it makes more than one solid.
If I write to PostGIS as TIN, It returns in the same chape back to FME,
but I can't calculate volume from TIN in PostGIS.
  • March 18, 2017
Hi @jernejtekavec, if you could read the objects as a TIN (mesh) surface closed in 3D, I think it could be transformed into a solid with two GeometryCoercers.
The first one (Geometry Type: fme_composite_surface) converts the mesh to a composite surface, and the second one (Geometry Type: fme_brep_solid) converts the composite surface to a brep (boundary representation) solid.
j_geo
  • March 20, 2017
Thanks for answer. But I'm still having troubles, that the solid that is read
from Postgis is not the same as the written one.
I tried to use two geometry coercers and it works, but the volume
that I calculate afterwards is not correct.
Regards!
Jernej
