I have a few thousand points in an SDE layer and I need to see which points intersect or overlay a polygon layer (hundreds of polygon features). Intersecting points will get a risk value assigned to them (I was thinking through a test filter and attribute creator). Non intersecting points just won't have a risk value and all points whether intersecting or not get written to a point featureclass I already have created in SDE. I've tried PointOnOverlay, Intersector, and even SpatialFilter but I must be setting this up wrong. Any ideas? Many thanks
Points that intersect polygons and points that don't
Best answer by ciarab
pointonareaoverlayer should work, points will get an overlap value of 1 if they intersect 1 polygon and so on. Are your 2 datasets in the same coordinate system?
