Thanks ahead for any guidance.
Points Distances from a Route
How can I calculate the closest distance from a point to a route? For example, distances of houses from a tornado path (equivalent to ESRI's Near function).
Best answer by takashi
I think NeighborFinder transformer is suitable for your purpose. Connect the point features to BASE port, the route feature to CANDIDATE port of the NeighborFinder. Set a preferable list name to "Close Candidate List Name" parameter of the transformer. Points within the specified maximum distance from the route go to MATCHED port. The points will have a list including the closest distance to the route.
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
