Output dictionary key and value pair from PythonCaller
  • Oct 18, 2017 4:20 PM UTC
  • 14 replies
  • 258 views
I have created a series of Dictionaries in the PythonCaller and I want to output the Key and Value pairs as new attributes with values for each feature.
Is there syntax using feature.setAttribute to do this?
  • Oct 18, 2017 4:27 PM UTC
Try something like this
for key, value in mydict.items():
    feature.setAttribute(key, value)
jdh
Forum|alt.badge.img+41
  • Oct 18, 2017 4:29 PM UTC
for k,v in d.items():
feature.setAttribute(k,v)
Note that you will have to explicitly expose the attributes to use them in the workspace
jdh
  • Oct 18, 2017 4:31 PM UTC
great minds and all that...
  • Oct 19, 2017 8:44 AM UTC
Thanks! The only issue is I won't know the name of the keys since they are created as part of the code. Is there anyway to expose them without knowing what they are called?
  • Oct 19, 2017 8:56 AM UTC
Even if you could expose them, what would you like do with the attribute names since they're not known when you're designing the workspace?
  • Oct 19, 2017 9:02 AM UTC
I would like to populate them with values found in a list.
My overall issue is that I have a number of lists. Inside one of the lists is the values that I would like to use as column headers in an excel spreadsheet and the values that will be under the column headers can be found in another one of the lists. I can't work out how to make the values in the list into column headers.
Perhaps there is another way to do this??
  • Oct 19, 2017 9:06 AM UTC
You'll have to use a writer configured for dynamic schema based on a schema feature (that you'll have to generate yourself). Look into the SchemaSetter on the FME Hub for a start.
  • Oct 19, 2017 9:10 AM UTC
This is a great starting point: https://knowledge.safe.com/articles/1051/index.html
  • Oct 19, 2017 9:56 AM UTC
Thanks David, I have managed to create the new attributes using 'AttributeCreator'
And when I set the Excel Writer Schema Sources to "Schema From Schema Feature" I am outputting an excel spreadsheet with the new column headers as I required.
However, I can't work out how to populate these column headers! I tried to populate them in AttributeManager like so:
But then in the excel spreadsheet the values of the column headers replaced the column headers themselves.
I seem to be missing one vital step here but I can't work out what it is.
Thanks,
  • Oct 19, 2017 10:13 AM UTC
Thanks,
I can't see your screenshot... Maybe it's easier if you post it as a separate question.
  • Oct 19, 2017 10:27 AM UTC
Hi David
I tried posting as a new question but there is an issue with my computer and screen shots are not working for some reason.
https://knowledge.safe.com/questions/56136/creating-a-schemafeature-and-mapping-values-to-it.html?
In essence my problem is now that I can create the new column headers using the Attribute Creator with the parameters as such:
New AttributeAttribute Valueattribute{0}.name@Value(_candidates{0}.Node_Label)_Distanceattribute{0}.fme_data_typefme_decimal(10,2)attribute{1}.name@Value(_candidates{1}.Node_Label)_Distanceattribute{1}.fme_data_typefme_decimal(10,2)attribute{2}.name@Value(_candidates{2}.Node_Label)_Distanceattribute{2}.fme_data_typefme_decimal(10,2)But I can't work out how to populate the new attributes names with the actual values (which are coming from another list).
Thanks,
  • Oct 19, 2017 10:37 AM UTC
Hi David
Thanks,
The problem is that you can't have functions inside your attribute values here, they aren't automatically evaluated by the writer. This means that you'll have to use the value of "@Value(_candidates{0}.Node_Label)_Distance", not the expression as a string.
  • Oct 19, 2017 10:48 AM UTC
Sorry I should have made myself clearer.
The functions inside the Attribute Value field in the AttributeCreator are being calculated correctly. I was able to create new attributes based on those functions. But my problem is that I can't populate the new attributes that were created with any values.
Thanks
  • Oct 19, 2017 10:50 AM UTC
Thanks
In that case I don't have enough information to help you out, sorry. Maybe consider posting more information (a minimal workspace to reproduce the issue would be best) on the separate question you created.
