OSM downloader failed
checcosisani
Forum|alt.badge.img+12
Hi
I tried to download some data using OSM downloader but I recevid an error
imagecan ypu help plesae ?
thx
Francesco
geomancer
Forum|alt.badge.img+53
  • March 30, 2023
The error mentions a rejected feature.
Your workspace is set to terminate when a rejected feature is encountered.
You can set your workspace to continue when a rejected feature is encountered (Workspace Parameters > Translation > Rejected feature Handling).
Rejected_Feature_Handling
checcosisani
  • March 30, 2023
yes I did but the osm donloader stop at the tester inside the bookmark "Make destination folder; Validate specified extents" so I suppose that something happens here
geomancer
  • March 30, 2023
The feature is rejected because it doesn't satisfy all conditions from the tester.
The feature is passed through the Rejected port, so you can inspect it and determine why it was rejected.
checcosisani
  • March 30, 2023
Ok thank's but what's is the reason ?
Which condition isn't satisfied ?
Last week works fine
now I rerun with different input now the issue is on the HTTP caller
 imageso OSM server congested, request too big, esri reprojector issue ?
Francesco
geomancer
  • March 30, 2023
If you cannot tell from the rejected feature, you can make a copy of the tester, and test on one condition at a time to find out which condition triggers the rejection.
hkingsbury
Forum|alt.badge.img+58
  • March 30, 2023
Francesco
Have a look at the message in the "_response_body" attribute coming out of the rejected port on that HTTPCaller
checcosisani
  • June 14, 2023
Hi
I tried to run the wb and for some municipalities it works for the the ones that not work I tried to use the QGIS plugin and I'm able to download the data so something happens in the custom transformer
