Oracle Spatial Writer not creating geometry
chris_acc
Forum|alt.badge.img+5
I am trying to read data Oracle non spatial data from a View and create an output in Oracle Spatial.
Although the process writes to the Oracle Spatial table and you can view the attribute data OK the data does not seem to be spatial and I can't see any data on a map.
FME_Parking_Oracle_IssueI have learned through passed experience that the Spatial Column must be
changed from GEOM to SHAPE
FME_Parking_Oracle_Issue_2Not sure if this is because i can't set the Eastings and Northings in the Reader to Types x_coordinate and y-coordinate?
You can set in a CSV Reader but not Oracle? (if this is the issue)
FME_Parking_Oracle_Issue_3
Thanks
Best answer by ebygomm
I think points are probably not generated automatically from the Eastings and northings column with the Oracle non spatial reader as they are with some other formats. You can use a vertex creator to use the values to create points
Forum|alt.badge.img+39
  • July 27, 2021
chris_acc
  • July 27, 2021
Perfect, thanks @ebygomm​ that worked 😉
