NTv2 transformation using own data grid
  • November 12, 2013
  • 82 views
Hello,
is it possible to transform e.g. shape-Files using the NTv2 - method and using an own data grid (ascii or binar) ?
Thanks for your answers
Isabell
  • November 12, 2013
this is a bit outside of my domain, but take a look under the menu Tools / FME Options / Coordinate Systems. I believe you can double-click on the entries to specify the grid shift file(s) there.
David
  • November 12, 2013
Hey David,
yes it's possible to specify the grid files there. But where can I tell FME that it should use the NTv2-method instead of a 7-Parameter-transformation?
I normally use the FME Translator to reproject my shape files or the reprojector in FME workbench.
Regards
Isabell
  • November 12, 2013
Hey David,
that was exactly what I needed!
Thank you very much!
Isabell
