Normalisation of street name with Python or Any Transformer
I am having problem to find a suitable way to normalise Street Name in my geodatabase.
Example of Street Name to be normalised;
Example List of abbrivations to search and replace;
Any idea how to solve it either with a transformer or Python Script.
Many Thanks!
Abdul
Best answer by takashi
Hope this works fine!
# PythonCaller Script Example (Python 2.7 only)
class FeatureProcessor(object):
    def __init__(self):
        self.map = None
    def input(self,feature):
        if self.map == None:
            search = feature.getAttribute('_map{}.To Search')
            change = feature.getAttribute('_map{}.To change')
            self.map = zip(search, change)
        name = feature.getAttribute('Street Name')
        for src, dst in self.map:
            name = name.replace(src, dst)
        feature.setAttribute('Normalized', name)
        self.pyoutput(feature)
# PythonCaller Script Example (works with both Python 2.7 and 3.5)
    def __init__(self):
        self.search = None
        self.change = None
        if self.search == None:
            self.search = feature.getAttribute('_map{}.To Search')
            self.change = feature.getAttribute('_map{}.To change')
        for src, dst in zip(self.search, self.change):
  • June 15, 2017
Your captures aren't showing, but in general you can use a series of StringReplacer transformers to search and replace text inside e.g. street name attribute.
mark2atsafe
Forum|alt.badge.img+51
Also there are some address postcode validators in the FME Hub that might be of use.
  • June 16, 2017
str-name-and-normalization-list-sample.xlsx
Hi David,
Thanks for your answer but they are so many about 100s and if I do with StringReplacer it will be much work and mess :). we have a python module for this problem from an other collegue but I can not intergrate it into FME because have not worked with Python.
Attach you can find the sample data.
  • June 16, 2017
    def __init__(self):
        self.map = None
    def __init__(self):
        self.search = None
        self.change = None
  • June 16, 2017
    def __init__(self):
        self.map = None
    def __init__(self):
        self.search = None
        self.change = None
hmm, I don't know why the script doesn't change any string with Python 3.5, though it seems to work fine with Python 2.7.
  • June 16, 2017
    def __init__(self):
        self.map = None
    def __init__(self):
        self.search = None
        self.change = None
Dear @takashi,
Thanks a lot. It is sort of working.
  • June 16, 2017
vdiyalshah wrote:
Dear @takashi,
Good to hear.
Note that the previous script works only with Python 2.7. I added another script that works with both Python 2.7 and Python 3.5
  • June 16, 2017
    def __init__(self):
        self.map = None
    def __init__(self):
        self.search = None
        self.change = None
OK. The behavior of "zip" function in Python 3.5 was different from Python 2.7. It's the reason why the previous script didn't work with Python 3.5 interpreter.
