neighbor finding based upon location and attributes
  • August 13, 2015
  • 54 views
tva
Forum|alt.badge.img+13
Hi all,
This is the situation: I have 2 lines (red and green) and a lot of points who should be matched to one or 2 of the lines. This works fine with the neighbourfinder but only in the cases where the lines aren't equal to each other. In the cases 16-3, 7-6, 8-5 and 9-4 the points who should be matched are on the same location and the lines are at that spot also equal to each other (I know it's a bad drawing but otherwhise it would be confusing :) )
If I do this with the neigborfinder (combined with list exploder) I get too much information (I'll explain with 1 point as its the same case for all points) in scenario 8-5 (circled in blue) I get information on point 8 from the red and green line and in point 5 I also get information on the red and green line while the situation I want to get is red information on point 8 and green information on point 5.
I need to find a way to get the right information out of it. I need to find a way to check in the neighborhood of point 8 to a point where the id is 1 higher or lower so that I can check which information is present in that point to see if it's equal
All tips and tricks are welcome :)
VAT
Best answer by david_r
Hi
The NeighborFinder can give you a list of all the "close candidates", i.e. all the lines that are within the maximum distance of each point. You need to specify an attribute name for "Close Candidate list name" in the NeighborFinder so that you can analyze the contents.
You might also want to switch the Base and Candidate features around, so that you look for all the points close to each line. It should be easier to check for incrementing series that way (hint: ListSorter).
David
  • August 13, 2015
Hi
David
