multiplication for all the value if with the same name
  • Aug 21, 2024 10:13 AM UTC
  • 9 replies
  • 273 views
chaoluo
Hi there, Anyone could help? I would like to build a FME workbench to run a multiplication for all the value if they are belongs to the same name. Attached a sample data e.g. I want to get the multiplication for armstrong_2006( 42*10*39*26), then I want the result to be added back in this spreadsheet. thanks.
Best answer by dustin
Use an Aggregator with the following settings:
  • Group by: ‘name’ field
  • Attributes to Concatenate: ‘value’ field
  • Separator Character: *
In an AttributeCreator, create a ‘result’ field with the expression @Evaluate(@Value(value)). This will multiply the value because we used * as the separator.
Finally, use a FeatureMerger with Requestor and Supplier both set to the ‘name’ field.
Hi Dustin, can I have a similar question to this? if the value are texts (A,B,C) how do I combine them into 1 row with separator of “,”? thanks
Use a comma as the Separator Character in the Aggregator, then in the AttributeCreator instead of @Evaluate(@Value(value)), use @Value(value).
mark2atsafe
Forum|alt.badge.img+59
Try the Aggregator transformer. Group-by on the name and use the Attribute to Sum parameter to pick the data field. The output will be one record per name with the sum of the values.
dustin
Forum|alt.badge.img+36
  • Aug 21, 2024 11:25 AM UTC
mark2atsafe
Sorry. You wanted multiplying, not addition. My bad.
chaoluo
  • Aug 21, 2024 1:29 PM UTC
Dustin, excellent.👍 I tried the workflow that you provided, it worked for me very well. Much appreciated.
chaoluo
  • Aug 21, 2024 1:30 PM UTC
no problem at all. thanks for your answer as well.
chaoluo
  • Aug 21, 2024 1:31 PM UTC
chaoluo
  • Aug 21, 2024 2:43 PM UTC
chaoluo
  • Aug 21, 2024 2:55 PM UTC
dustin
  • Aug 21, 2024 3:02 PM UTC
