Multiple shapefiles with different schema
  • July 19, 2013
  • 44 views
I have hundreds of shapefiles for which I need to transform coordinate systems and I have a custom built transformer to transform the coordinate system.
My issue is that each shapefile has a different set of field names.  I don't want to have to link up each input and output manually and have a hundred different workbenches, one for each shapefile.
I want to be able to bach transform all the shapefiles, but keep the field names the same in each output file as each input file.
I am using FME 2012 desktop.
Any advice would be greatly appreciated.
Thanks,
fmelizard
Forum|alt.badge.img+22
  • July 19, 2013
HI,
This is a typical case for the dynamic translation mode (no need to map the attributes) in combination with a writer fan out.
Itay
  • July 19, 2013
I strongly agree Itay. I believe It's one of the most typical and also effective use cases of dynamic schema functionality.
I think learning this documentation will be a good starting point to understand dynamic schema. Example 1 of this documentation is similar to your case.
Takashi
  • July 19, 2013
Thanks Takashi,
I have just tried the Dynamic Schema but am getting an error.  Please see my other post
  • July 19, 2013
