Multiple Records out to the same JSON file
  • Sep 26, 2019 6:42 PM UTC
  • 275 views
richardsr
Hello Community,
I am having some challenges writing multiple records into a valid json output. What I have is working using a text writer but it is missing the comma "," between the individual records. I was about to explore building a list and change my json template or do i need an aggregate? I seem to be confusing myself with this small detail.
Below is an example of my current output into a text writer. I pretty much followed the Json Writer article (https://knowledge.safe.com/articles/44294/json-writing-with-jsontemplater.html ) which was a huge help but the difference here is I am fanning the output by date so multiple records will be written I just cannot figure out how to make the json valid.
20190711.json
I believe just need a comma to separate these 2 records to make it valid
Any help would be appreciated!!
Thanks
Ronnie
Best answer by daveatsafe
Hi @richardsr,
I think another JSONTemplater might be the best idea - it will both add the commas and the surrounding '[]' for the array:
daveatsafe
Forum|alt.badge.img+24
  • Sep 26, 2019 7:11 PM UTC
Hi @richardsr,
richardsr
  • Sep 26, 2019 10:25 PM UTC
Hi @richardsr,
Thank you so much for the quick response and suggestion. This looks really close now and the only issue I have not is it seems to be escaping the valid json which was being passed into the SUB template. Any ideas how to remove the extra " & \\ characters?
daveatsafe
  • Sep 26, 2019 10:39 PM UTC
You need to use fme:get-json-attribute("text_line_data") instead of fme:get-attribute("text_line_data"). This will not escape the JSON.
richardsr
  • Sep 26, 2019 10:52 PM UTC
That was it!! Thank you so much!!
