Might there be a bug in the XQuery function fme:process-features (JSONTemplater)
  • February 16, 2017
  • 5 replies
  • 111 views
Hi !
When using the JSON Templater, loading sub-templates using the xquery fme:process-features, I get an error when one of my json documents (generated by a previous JSON Templater) contains an ampersand (&)
Here is the error :
JSONTemplater_Annonce(XMLTemplaterFactory): invalid expression: syntax error, invalid character or entity reference "& ASSO..." in the string literal "CABINET PIERRE SMITH & ASSOCIES".
Could it consider the ampersand to be a reserved character of the xquery language even whitin double-quotes ?
  • February 16, 2017
Maybe someone else can confirm, but I suspect that the ampersand is considered a special character in XQuery, cf. https://en.wikibooks.org/wiki/XQuery/Special_Characters
Try using a StringReplacer to replace the ampersands with either "&" or to "&".
  • February 16, 2017
Yes, in XQuery expressions, the ampersand can only be represented using the entity reference or character reference. See also this link.
W3C Recommendation | XQuery 3.0: An XML Query Language | 2.4.5 URI Literals
This expression causes the error.
    "CABINET PIERRE SMITH & ASSOCIES": "foo bar"
To avoid the error,
a) escape the ampersand with the predefined entity reference (&),
b) or save the string literal as a feature attribute (e.g. called "name") beforehand and use FME predefined XQuery function "fme:get-attribute" to put the value in the expression.
    fme:get-attribute("name"): "foo bar"
Note: Since the function escapes the ampersand internally when the expression is evaluated, you don't need to replace the ampersand within the "name" attribute value with the entity reference.
  • February 17, 2017
To avoid the error,
Ok ! Thanks for the answer ! If I use "&" do I need to replace it back when loading it (I will use a python caller, load the json in a python dictionnary, then write it in mongodb) ?
What's bother me though, is that I indeed used fme:get-attribute to create the json structure in a previous JSON Templater, then used the resulting json attribute in the second JSON Templater as a sub-template... (I guess that's why the & is no-longer escaped, the nested json might be passed as a raw string somewhere inbetween)  maybe if I define all the nested sub-templates in the same json templater, the & would be correctly escaped... I will try that.
  • February 17, 2017
I don't think the error could occur even if you are using multiple JSONTemplaters in a series, unless an ampersand exists within a string literal in a template expression. Can you post a workspace example which illustrates your problem?
  • February 21, 2017
Yes ! I will try to create a specific workspace to showcase this
