Merging Raster and Vector with Transparency
pratap
Forum|alt.badge.img+11
Hi All,
I have kml and image as input files. The requirement is to generate another image by merging both. I have merged both and able get the raster, but I'm not getting transparency in the area within the polygon.
I have attached pdf file of requirements and workbench for better understanding...
Thank you
Pratap
Forum|alt.badge.img+49
You can put the raster in the MapnikRasterizer as well. Alternatively, the VectorOnRasterOverlayer gives you a simpler option to do the same thing (but has less options to control how the action is performed)
pratap
  • February 7, 2023
Hi @Hans van der Maarel​
I have already used MapnikRasterizer transformer but the result is not as required. I have attached workbench to this thread for reference.
Forum|alt.badge.img+38
  • February 7, 2023
If you just want an outline, i would coerce your polygon to a line with a GeometryCoercer and use that linegeometry
