Merging multiple attributes
  • Jan 16, 2018 12:15 PM UTC
  • 141 views
Hello,
I am making a workbench that closes polygons and add them multiple attributes from shape file. I succeeded to do that but now I am facing a problem because for example I have ~1300 polygons that are area and I am using NeighborFinder to relate it with parcel number and some more names. My problem is that some polygons have multiple information, for example, some parcels have parcel number, name of region, name of municipality and name of river crossing it. All these attributes should be assigned to one parcel number and one polygon but it is not what is happening.
I am attaching screen shots of my problem.
In this picture You can see that for example parcel no 1588 have more attributes then just parcel number but I don't know what reason for it is not being merged.
pratap
Forum|alt.badge.img+12
  • Jan 16, 2018 12:41 PM UTC
If I understood your question correctly, Try PointOnAreaOverlayer once and let me know
Pratap
Pratap
test-model.fmw
It says translation failed, I don't know what's the problem.
pratap
  • Jan 16, 2018 1:02 PM UTC
test-model.fmw
You have connected lines to area port. Kindly remove and execute
  • Jan 16, 2018 2:27 PM UTC
Hi @maliodpalube, the NeighborFinder merges only attributes of the closest candidate feature to the matched base feature. If you need to merge attributes of three point features from different feature types to a base feature, I think cascading three NeighborFinders like this would be an easy way.
