Merges polygon features based on a specified distance and field values
  • Feb 28, 2018 9:02 PM UTC
  • 336 views
What would be the equivalent in FME of the ArcGIS "MergeAggregate" function which allows to merge polygon features based on a specified distance and field values?
Thank you
  • Mar 1, 2018 10:38 AM UTC
Have you got the licence for MergeAggregate in Arcgis?
  • Mar 1, 2018 12:02 PM UTC
Hi @bergeronfrank, if your requirement is to aggregate polygons which have an identical value in a specified attribute (e.g. "_group") and also are within a specified distance (e.g. "_distance") each other, this workflow might help you.
  1. Bufferer (Group By: _group, Buffer Amount: _distance * 0.5): Create buffers of the polygons. The buffers that belong to the same "_group" and touch or overlap each other will be dissolved here.
  2. Counter: Add sequential number to the buffers as temporary ID (e.g. "_id").
  3. SpatialFilter: Send the buffers to the Filter port, send the original polygons to the Candidate port, make sure that the Merge Attributes option is checked. With this setting, "_id" of a buffer will be transferred to the polygons within it.
  4. Aggregator (Group By: _group, _id): Aggregate the polygons output from the Passed port of the SpatialFilter, grouping by "_group" and "_id".
itay
Forum|alt.badge.img+19
  • Mar 1, 2018 1:03 PM UTC
You can also calculate the distance between features and aggregate via the neighborhoodaggregator.
Thank you @takashi and @itay. I will try your recommendations
