Merge records into single row per key
I have this data below which I would like to transform into a single record per row.key. How do I do it?
Ideal output would be 2 records with field.name converted to columns.
Cheers
Best answer by ebygomm
I would typically create a new attribute using the field.name value and set it to the value of field for each record. Then expose these attributes and then aggregate based on row.key. This assumes you know all possible field.names to expose
e.g.
Forum|alt.badge.img+38
  • July 24, 2018
e.g.
fmelizard
Forum|alt.badge.img+18
  • July 24, 2018
e.g.
Yep, that is the best way I'm aware of. I'd make the minor additional suggestion to tell the Aggregator NOT to assemble any geometry (the Mode -- set it to Attributes Only) -- that will save it some work.
  • July 25, 2018
e.g.
awesome stuff! thanks!
  • July 25, 2018
In relation to this one, Given the xml below
emp-record-sample.xml
I get this after XML Fragmenter
Is there a way that after it goes through the aggregator it concatenates the field.name "GIVEN_NAMES" into a single column? Or is it better to edit the XML and change one of the "GIVEN_NAMES" into say "FIRST_NAME" so I could exppose them separately?
Right now, I am getting this one below after AttributeExposer and just ignores the 2nd Given Name after going through Aggregator.
TIA
  • July 25, 2018
e.g.
I often use the BulkAttributeRenamer, rather than the AttributeCreator. FYI.
