Merge gaps between polygons using attribute value
  • Jun 25, 2020 12:19 PM UTC
  • 5 replies
  • 289 views
ronan
We face a problem correcting the geometry between multiple polygons in a layer.
There are some gaps between polygons and we need to automatically fill them. We identified 2 ways to fill the gaps between 2 polygons, explained in the following chart.
We tried the first solution using dossolver and Donut Hole extractor, but there are some line left after the process (maybe due to the different positions of the shape vertex on the grid). So we don’t know if our process is the best to succed ? if yes , how to fix this problem ?
Best answer by ronan
Yes but this transformer cut overlapped polygons, we need to keep the overlapping
Forum|alt.badge.img+54
  • Jun 25, 2020 12:21 PM UTC
Have you tried the AreaGapAndOverlapCleaner?
ronan
  • Jun 25, 2020 12:25 PM UTC
  • Jun 25, 2020 12:39 PM UTC
I'd still be tempted to use it and then add the overlapping areas back in afterwards, something like this
ronan
  • Jun 25, 2020 12:53 PM UTC
Thanks, we are testing , we are giving you a feedback quickly
ronan
  • Jun 25, 2020 1:51 PM UTC
Thantks a lot, the process you describe is working. We are even testing a process with the same philosophy but more simple :
