Merge duplicate appearances
Hello,
From a colleague I received an export from Navisworks in fbx (originally created in Inventor). The model consists out of many objects, which I would like treat separately.
Therefore I added an identifier to the attribute table. After finishing the workbench in FME for an individual object, I want to create an iterative process to perform an analysis for all objects (by using a loop-transformer).
The geometry of an object can be de-aggregated to parts. Of each part, the appearance can be extracted. However, the table contains duplicate values of material. I wish to merge rows with the same value of the field "fme_style_appearance_name".
Simultaneously (this may be a misunderstanding from my side), geometry with corresponding part numbers must be merged as well.
How can this be realised? It is possible to identify duplicate values by using the matcher-transformer, but unfortunately I don't know how to continue the process.
Kind regards,
Pim van der Zwaag.
FME versie 2018.1.1.2 (20190121), build 18586 (64 bit)
(the fbx-file can be provided..)
daveatsafe
Forum|alt.badge.img+19
  • March 21, 2019
Hi @pzwaag,
I am a little unclear on what you want to output. Is it a list of appearance names, or do you want to join parts with same appearance into a larger object?
erik_jan
Forum|alt.badge.img+20
  • March 21, 2019
Duplicate values can be found using the DuplicateFilter transformer. Use the Unique output port to get the unique values.
  • March 25, 2019
daveatsafe wrote:
Hi @pzwaag,
Hello Dave,
Thank you for your reply. I might have been unclear, sorry for that. I am not familiar with these types of data.
What I would like to achieve is the second option you mentioned in your reply.
Thank you in advance!
Kind regards,
Pim van der Zwaag.
daveatsafe
  • April 8, 2019
Hi @pzwaag,
I'm sorry about the delay in responding. I think we can do this, but it would very helpful to have the FBX file to do some testing first. Please send me a download link: .
daveatsafe
  • April 18, 2019
Hi @pzwaag,
The attached workspace will break up the existing model in the FBX file, then rejoin the parts by common appearances.
mergebyappearance.fmw
