Many points in many polygons
  • September 2, 2016
  • 7 replies
  • 87 views
I have many polygons containing many points and polygons can overlap. I need to create an output that will contain as many polygon records as their are points inside. That way I can compare the attributes of the polygon with the attributes of all the points inside. I am using SpatialRelator with the polygons as the Requestor and the Points as the Supplier. Then a Listexploder, but the output of the point attributes are scrambled.
Best answer by owen
If in doubt use prefix list name to keep the right list attribute
erik_jan
Forum|alt.badge.img+26
  • September 2, 2016
I would use the PointonAreaOverlayer (generate a list), then the ListExploder on the Area output port of the PointonAreaOverlayer. That should give you the required result.
  • September 5, 2016
Thank you erik_jan
I have tried this but the point attributes just gets repeated. So if I have for instance 1 polygon overlapping 4 points with id's 1,2,3 and 4 then the results will contain 4 records (which I am happy with), but all the point ids will be = 1. On the PointOnAreaOverlayer I have tried Areas First Yes and No - Same result. Thank you
Forum|alt.badge.img+54
  • September 5, 2016
Thank you erik_jan
If you have an id field in both your area and point features then you probably need to set conflict resolution under attribute accumulation to "Use Incoming"
owen
  • September 5, 2016
  • September 6, 2016
The point and area shapefiles does not contain the same attribute names. The id field in the point layer is call 'entity-id' and in the polygon layer 'guid'.
  • September 6, 2016
OK, Prefix_incoming produced the needed results. Not sure why and how. Thank you Owen.
owen
  • September 6, 2016
when you build a list the attributes of the first record get appended as well. by prefixing the list attributes you make sure you only keep those and there is no conflict
