Loading AutoCAD .DWG in FME Viewer 2012 SP4 Issue
All,
I currently have FME Viewer 2012 SP4 and am trying to load an AutoCAD .dwg file supplied to me by an end user.  However, I am getting an error in the log as followed:
"FME API version of module 'REALDWG' matches current internal version (3.7 20111219) AutoCAD Reader: Unknown or unsupported version of AutoCAD file 'AC1027'. Most recent supported version is 'AC1024', which is also known as 'Release2010'"
Does upgrading to FME 2013 fix this, or is it a known issue being worked through?
Thanks for any help in advance!
  • April 5, 2013
Hi Nick,
from the list of news in FME2013 SP1, this looks like it might be relevant to your question:
 ACAD,CIVIL3DAdded general DWG 2013 support and limited 2010-2012 Civil support (C28401 C47466 C47934 C51809 C52068 C60900 C61156 C62407 C65082 C67988 C68333 C71674 PR#30797 PR#39438 PR#39483)
I would simply download and install FME2013 SP1 and test. You can have both versions installed on the same machine without problems, just make sure you specify a different location than the one used by FME2012 during installation.
David
  • April 5, 2013
David,
Thanks for the quick reply! I will give this a shot, but it might not be until the end of next week that I let you know if it helped.  I am on vacation until April 10th at the end of today :)
Have a good one!
Nick
