Linking a Parameter to the Prefetch Query on Joiner
  • Apr 9, 2013 7:56 PM UTC
  • 6 replies
  • 124 views
I'm trying to build a dynamic SQL string to use as my Prefetch query on a Joiner transformer.  I am linking a Python script Private Parameter to the Prefetch query parameter on the Joiner.  I am using the Python script to construct the query, something like
return "select * from " + FME_MacroValues["SchemaOwner"] + ".TABLE_NAME".
When I run the workspace I get the message
An error occurred while accessing a table result for feature type `__fme_execute_sql_results__'; message was `Execution of statement `select' did not succeed; error was `ORA-00936: missing expression'.
However, if I copy the SQL statement from the Python script with the parameter substitution for the database schema name into the Prefetch query parameter on the Joiner, the query executes successfully.
Is there a way to create a dynamic SQL statement for a Prefetch query?  I am currently using a beta copy of FME 2013.
Thanks,
Steve
davideagle
Forum|alt.badge.img+21
  • Apr 9, 2013 8:05 PM UTC
Above or below that statement in the log file you should be able to see how the SQL is being issued to the database. Can you see if the substitution is happening as planned in the log?
  • Apr 9, 2013 8:13 PM UTC
Here are the lines around the error message:
Connected to ORACLE database `framme2003wg'
Environment variable ORACLE_HOME has value `D:\\apps\\oracle32\\product\\11.2.0\\client_1'
Connecting to ORACLE database `framme2003wg' with user name of `xxx' and password of `***'
Opened table `DGS_SHAPE:WPDBA.DGS_SHAPE' for input with server type `ORACLE8I_DB', server name `framme2003wg', user name `', database name = `';
ORACLE Reader: Using Oracle 8 SC Reader to read tables from database `', server type `ORACLE8i', server name `framme2003wg', user name `xxx', password `***'
ORACLE Reader: Using Rich geometry.
An error occurred while accessing a table result for feature type `__fme_execute_sql_results__'; message was `Execution of statement `select' did not succeed; error was `ORA-00936: missing expression'. (serverType=`ORACLE8i', serverName=`framme2003wg', userName=`xxx', password=`***', dbname=`')' (server type is `ORACLE8i', server name is `framme2003wg', username is `xxx', password is `***', database name is `')
@Relate: Failed to execute prefetch query. Continuing with incomplete cache
ORACLE Reader: Executing SQL Statement `SELECT "WPDBA"."DGS_SHAPE"."FILENAME", "WPDBA"."DGS_SHAPE"."RB_PRMRY" FROM "WPDBA"."DGS_SHAPE" WHERE FILENAME = :binding0' to obtain features for feature type `WPDBA.DGS_SHAPE'
I do not see the SQL for the query that should be returned from the Python script.  I believe the query that is being shown is the "default" query that would be run if I didn't specify a prefetch query.
  • Apr 9, 2013 9:08 PM UTC
Ok, this is weird.  I added the print statement and confirmed that the Python script is formatting the SQL select statement correctly as expected.  However, what I see in the error message
is telling me that the SQL passed to Oracle was just "select".  If I change the Python script and take out all the spaces in the select statement I am formatting I see an error message like
Execution of statement `selectrb_prmry,lower(trim(replace(filename,'.dgn',NULL)))filenamefromWPDBA.DGS_SHAPE' did not succeed
It appears that my SQL statement returned by the Python script is getting truncated at the first space in the string before it is being sent off to Oracle.  Is there some setting to preserve spaces within a parameter string?
davideagle
  • Apr 9, 2013 9:18 PM UTC
I've had some assorted challenges like this before and I wonder if you're hitting a similar issue. Can you try different variations of quotes and double quotes. I'm pretty sure you might even need to try doubling up your escape characters. Sorry I can't be more help, I'm not clear on the rules of how the statement is being parsed so it might be a matter of trial and error. If you hit the wall then escalate the issue direct to Safe using the support option above. Best of luck.
  • Apr 10, 2013 6:55 AM UTC
if you're passing parameter values to FME over the command line that contains spaces, you will have to enclose them with double quotation marks ("...") to prevent the command line interpreter from splitting them. Example:
fme.exe myworkspace.fmw --Param1 "A parameter value" --Param2 "Another value"
The quotation marks themselves will not be passed on to FME.
David
  • Apr 10, 2013 11:44 AM UTC
That was the answer.  If I return the SQL statement with double quotes around it from the Python script, the SQL is passed and executed correctly in the Joiner.
Thanks to all for the suggestions!!
Steve
