Linked Custom Transformers - Multiple workspace repositories
sigtill
Forum|alt.badge.img+24
Is it possible in FME Server 2016 or 2017 to upload Linked custom Transformers to one particular Workspace Repository (for instance called "Common linked Custom transformers") and have several workspaces in different workspace repositories use this - so you only need to upload the Linked Custom Transformers one place, and all workspaces that uses this will get updated? Instead of having to upload every fmx file to all workspace repositories that uses these for each change?
Sorry for the long explanation, I hope it is clear enough!
Best answer by verdoodtdries
I don't know if that is possible, but you can upload your custom transformers to the FME_SHAREDRESOURCE_ENGINE folder. It is accessible through Resources > Engines > Transformers.
Custom transformers published in here can be used in every workspace running on FME Server.
Is this a workaround for your problem ?
verdoodtdries
Forum|alt.badge.img+19
  • April 19, 2017
sigtill
  • April 19, 2017
Great! This should work!
